Help - Configure Tools
hadfieldjohn
Hi.
I'm using 7.1.5.1398 and trying to set up a specific configuration of a diff tool using the Tools, Configure Tools menu option.
My executable/script setting is:
C:\Program Files\PLSQL Developer 7\ExamDiff\ExamDiff.exe
and my parameters is:
"c:\release\#file" #path
I seem to have two issues. The first is that the double quotes don't seem to be forcing a long-form filename. The second is that both 'variables' don't seem to be being resolved as I get an error "#path could not be found".
Am I missing the point or is something not working correctly?
John
