generated sql statements for DOA components
Johan R
The DOA components generate their own sql statements, this depends on the fields that are changed.
For example: when a Toracledataset contains 3 fields an only 2 are changed, the TOracledataset generates an sql statement like
update
set = :v1
, = :v2
or
insert into
(field1, field2)
values
(:pv1, :pv2)
Because has not been changed, it is not in the generated sql statement.
Because of the shared pool in Oracle (which contains the last statements) I would like that the TOracleDataset component generates always the same insert and update statements for a specific set of data (not depending on which fields are changed)
Is that possible?
