F6 does not work in when executing SQL in debug window
Claus Pedersen
This is a repost from the beta 15 forum.
When executing SQL in debug window, code assistant now works. Thanks.
But F6 does not activate code assistant, when e.g. correcting some code and you wish to activate code assistant manually.
When you Ctrl-click on a hyperlink in the execute SQL window, the code is opened in a new window, but still with the SQL popup on the top. You can not get back to the test window tab page, you will have to execute/close the SQL popup and then shift back to the test window.
Please make sure that when Ctrl-clicking on a hyperlink, the source is opened in a new window, but this window is not given focus, focus should be on the current test window tab page.
Can these two issues be fixed?
