Stew Stryker
When I try to export my SQL results set that includes a CLOB in SQL format, I get the error message:
One or more columns are too long to export as SQL. The limit is 4000 bytes.
These CLOBS are text, just too long to store as VARCHAR2.
I understand that you can't just generate INSERT statements for these, as the INSERT limits the length. At least for text CLOBs, I think you could insert part, then update that row with the remaining part(s). I've used that technique before, but it's been table-specific.
Could you please add this to the enhancements list?
Stew
Stew
