error in SQL Editor
jto
I've just experienced incorred SQL editor behaviour in PL/SQL Developer
Version 6.0.5.926 (MBCS)
xxxxxx - 10 user license
Test case
1, open SQL window (or test window...)
2, write:
select '1','2' from dual
3, mark the characters from 1 to 2 (including the digits)
4, press Enter
instead of getting
select '
' from dual
I got
select '1','2
1','2' from dual
Can you reproduce it?
Can it be fixed?
best regards
Jiri
Jiri,
Works OK for me on this config ....
PL/SQL Developer
Version 6.0.4.906 (MBCS)
Windows 2000 version 5.0 (build 2195) Service Pack 4
Maybe a Windoze problem ;-)
Regards,
D.
Do you perhaps use a Plug-In like SmartEd or PL/Shortcuts? If so, can you disable them (Tools > Configure Plug-Ins), restart PL/SQL Developer, and try again?
you are right - it's SmartEd. Sorry for the accusal! ;)
best regards
Jiri
