Error dialog with just OK button and title plsqldev and red X icon
manoom
When I drag a table to Query Builder, some error occurs and I don't get the Query Builder. I get a small dialog window without any error message. It has title 'plsqldev' all in lower case, a red circle with X in it and OK button.
Maybe this is an environment problem. Can you start PL/SQL Developer without connecting, go to Help > Support Info and send me the text from the "Info" tab page?
PL/SQL Developer
Version 9.0.6.1665
12.84516 - Unlimited user license
Windows (64-bit) 6.2 Build 9200
Physical memory : 2,097,152 kB (2,097,152 available)
Paging file : 4,194,304 kB (2,957,172 available)
Virtual memory : 2,097,024 kB (1,855,092 available)
Parameters
C:\APPS\PLSQLDeveloper\plsqldev.exe
Preferences
Session mode: Multi
OCI Library: C:\APPS\PLSQLDeveloper\InstantClient\oci.dll
Use OCI7: False
Preference Files
C:\APPS\PLSQLDeveloper\Preferences\Default\default.ini
D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM\default.ini
Plug-Ins
*Active Query Builder (C:\APPS\PLSQLDeveloper\PlugIns\ActiveQueryBuilder.dll)
*PL/SQL Documentation (plsqldoc) (C:\APPS\PLSQLDeveloper\PlugIns\plsqldoc.dll)
*Red Gate Deployment Plug-In (C:\APPS\PLSQLDeveloper\PlugIns\RedGate.dll)
*Version Control Interface 1.2 (C:\APPS\PLSQLDeveloper\PlugIns\VCS.dll)
(* is Active)
Aliases
(ADDRESS
(ADDRESS_LIST
(CONNECT_DATA
(DESCRIPTION
Homes
OraClient12Home1_32bit (C:\APPS\OraClient\OraHome_12c)
DLLs
C:\APPS\OraClient\OraHome_12c\oci.dll
TNS File
\\file3\windows\orant\network\admin\tnsnames.ora
Using
Home:
DLL: C:\APPS\PLSQLDeveloper\InstantClient\oci.dll
OCI: version 11.1
Oracle Database 12c Enterprise Edition Release 12.1.0.2.0
Character Sets
Character size: 1 byte(s)
CharSetID: 178
NCharSetID: 2000
Unicode Support: True
NLS_LANG:
NLS_CHARACTERSET: WE8MSWIN1252
This looks okay. To obtain some more diagnostic information, can you modify the PL/SQL Developer shortcut and add the DebugSQL parameter? For example:
"C:\Program Files\PLSQL Developer 12\plsqldev.exe" DebugSQL
Reproduce the problem and send me the debug.txt file that is generated in the %APPDATA%\PLSQL Developer 12 directory (e.g. C:\Users\\AppData\Roaming\PLSQL Developer 12).
Is there a way to upload a file? For now pasting the file content here:
PL/SQL Developer
Version 9.0.6.1665
Paging file : 4,194,304 kB (2,534,112 available)
Virtual memory : 2,097,024 kB (1,938,344 available)
Parameters
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
9/6/2018 11:08:21 AM Application started
9/6/2018 11:08:21 AM InitPreferences
9/6/2018 11:08:21 AM Load C:\APPS\PLSQLDeveloper\Preferences\Default = 0
9/6/2018 11:08:21 AM PreferenceSet.Load C:\APPS\PLSQLDeveloper\Preferences\Default\default.ini
9/6/2018 11:08:21 AM PreferenceSet.Load OK
9/6/2018 11:08:21 AM Determine LocalPrefPath
9/6/2018 11:08:21 AM [1]: D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences
9/6/2018 11:08:21 AM LocalPrefPath: D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM
9/6/2018 11:08:21 AM Load D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM = 0
9/6/2018 11:08:21 AM PreferenceSet.Load D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM\default.ini
9/6/2018 11:08:21 AM PreferenceSet.Load D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM\user.prefs
9/6/2018 11:08:21 AM InitPreferences end
9/6/2018 11:08:21 AM SortPreferenceSets
9/6/2018 11:08:21 AM - Default ManooM
9/6/2018 11:08:21 AM DoUpdateChildList
9/6/2018 11:08:21 AM FindPassword starts for @itdbs_kerb
9/6/2018 11:08:21 AM Check current connections...
9/6/2018 11:08:21 AM Check connection definitions...
9/6/2018 11:08:21 AM FindPassword ends for @itdbs_kerb, no result
9/6/2018 11:08:21 AM FindPassword starts for @ITDBT_KERB
9/6/2018 11:08:21 AM Checking @itdbs_kerb...
9/6/2018 11:08:21 AM FindPassword ends for @ITDBT_KERB, no result
9/6/2018 11:08:21 AM pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
9/6/2018 11:08:21 AM ReadString OK
9/6/2018 11:08:21 AM pfReadRegistry: "C:\APPS\PLSQL DEVELOPER\PLSQLDev.exe" "%1"
9/6/2018 11:08:21 AM LoadPreferences
9/6/2018 11:08:21 AM LoadPreferences searching for default
9/6/2018 11:08:21 AM D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM\default.ini
9/6/2018 11:08:21 AM LoadPreferences NewPref := nil
9/6/2018 11:08:22 AM LoadPreferences Reading preferences
9/6/2018 11:08:22 AM LoadPreferences ReadPosition
9/6/2018 11:08:22 AM LoadPreferences ToolsBrowserItemClick(nil)
9/6/2018 11:08:22 AM LoadPreferences CreateBrowserFilters...
9/6/2018 11:08:22 AM LoadPreferences Files
9/6/2018 11:08:22 AM LoadPreferences Buttons
9/6/2018 11:08:22 AM LoadPreferences Printer
9/6/2018 11:08:22 AM LoadPreferences FileBrowserFolders
9/6/2018 11:08:22 AM LoadPreferences Connections
9/6/2018 11:08:22 AM LoadPreferences BrowserFolders
9/6/2018 11:08:22 AM LoadPreferences end
9/6/2018 11:08:22 AM MacroLibFilename: C:\APPS\PLSQLDeveloper\Macro\ManooM.emlib
9/6/2018 11:08:22 AM Logging on..
9/6/2018 11:08:22 AM Creating new session
9/6/2018 11:08:22 AM Initializing new session
9/6/2018 11:08:22 AM Setting new session parameters
9/6/2018 11:08:22 AM Setting logon session
9/6/2018 11:08:22 AM OCI Initialization starts
9/6/2018 11:08:22 AM OCI Initialization done
9/6/2018 11:08:22 AM OCIDLL forced to C:\APPS\PLSQLDeveloper\InstantClient\oci.dll
9/6/2018 11:08:22 AM Logon2 starting
9/6/2018 11:08:22 AM Logon2.Execute starts
9/6/2018 11:08:25 AM TOracleSession $06740F30 Start Session.LogOn as @itdbs_kerb
9/6/2018 11:08:26 AM TOracleQuery Query Start Query.Execute
9/6/2018 11:08:26 AM TOracleQuery Query End (1 record processed)
Duration = 0.046
9/6/2018 11:08:26 AM TOracleSession $06740F30 End
Duration = 0.796
9/6/2018 11:08:26 AM Logon2.Execute done
9/6/2018 11:08:26 AM Logon2 done
9/6/2018 11:08:26 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
9/6/2018 11:08:26 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.031
Duration = 0.062
9/6/2018 11:08:26 AM TOracleQuery $0670AE60 Start Query.Execute
SQL = begin :n := user; end;
:N = Null
9/6/2018 11:08:26 AM TOracleQuery $0670AE60 End
Duration = 0.016
SQL = select * from v$version
9/6/2018 11:08:26 AM TOracleQuery Query End (5 records processed)
Duration = 0.063
sys.plsqldev_authorization
Duration = 0.047
9/6/2018 11:08:26 AM LogonHistorySave start
9/6/2018 11:08:26 AM ChangeUserPref LogonHistory,
9/6/2018 11:08:27 AM ChangeUserPref DSA,
9/6/2018 11:08:27 AM ChangeUserPref end
9/6/2018 11:08:27 AM ChangeUserPref ColumnAssociations,
9/6/2018 11:08:27 AM ChangeUserPref ImportAssociations,
9/6/2018 11:08:27 AM ChangeUserPref BrowserFilters,
9/6/2018 11:08:27 AM ChangeUserPref FileBrowserFolders,
9/6/2018 11:08:27 AM ChangeUserPref Connections,
9/6/2018 11:08:27 AM ChangeUserPref BrowserFolders,
9/6/2018 11:08:27 AM ChangeUserPref SessionQueries,
9/6/2018 11:08:27 AM ChangeUserPref ExternalTools,
9/6/2018 11:08:27 AM ChangeUserPref Documents,
9/6/2018 11:08:27 AM ChangeUserPref Reports,
9/6/2018 11:08:27 AM ChangeUserPref CurrentConnections,
9/6/2018 11:08:27 AM PreferenceSet.Save
9/6/2018 11:08:27 AM PreferenceSet Filename = D:\Users\ManooM\AppData\Roaming\PLSQL Developer\Preferences\ManooM\user.prefs
9/6/2018 11:08:27 AM PreferenceSet AltFile = user.prefs
9/6/2018 11:08:27 AM PreferenceSet.Save end
9/6/2018 11:08:27 AM LogonHistorySave end
9/6/2018 11:08:27 AM FormCreate Logon.Executed -1
9/6/2018 11:08:27 AM FormCreate SessionChanged
9/6/2018 11:08:27 AM TOracleQuery Query Start Query.Execute
9/6/2018 11:08:27 AM TOracleQuery Query End (5 records processed)
Duration = 0.047
9/6/2018 11:08:27 AM TOracleQuery $0670AD00 Start Query.Execute
9/6/2018 11:08:27 AM TOracleQuery $0670AD00 End
Duration = 0.047
9/6/2018 11:08:27 AM SessionChanged SetDBAViews
9/6/2018 11:08:27 AM TOracleQuery $0670AD00 End (0 records processed)
Duration = 0.032
Duration = 0.047
9/6/2018 11:08:27 AM TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
:N = Null
9/6/2018 11:08:27 AM TOracleQuery PLSQLDevForm.DynamicQuery End
Duration = 0.016
9/6/2018 11:08:27 AM SessionChanged Authorizations.Load
9/6/2018 11:08:27 AM SessionChanged EnableAuthorizedMenus
9/6/2018 11:08:27 AM WindowAllowed(1)
9/6/2018 11:08:27 AM WindowAllowed done
9/6/2018 11:08:27 AM ExecuteConnectScript starts
SQL = alter session set plsql_optimize_level = 2
Duration = 0.032
SQL = alter session set plsql_code_type = interpreted
Duration = 0.032
SQL = alter session set plscope_settings = 'identifiers:none'
Duration = 0.015
9/6/2018 11:08:27 AM ExecuteConnectScript ends
9/6/2018 11:08:27 AM SetSessionAction starts: Primary Session
SQL = select null from dual
9/6/2018 11:08:27 AM TOracleQuery $0670AD00 End (1 record processed)
Duration = 0.047
:ACTION = Primary Session
Duration = 0.016
9/6/2018 11:08:27 AM SetSessionAction ends
9/6/2018 11:08:27 AM SessionChanged LoadRecentObjects
9/6/2018 11:08:27 AM SessionChanged Notify children
9/6/2018 11:08:27 AM SessionChanged Logoff secondary sessions
9/6/2018 11:08:27 AM SessionChanged EnableChildFunctions
9/6/2018 11:08:27 AM Lock
9/6/2018 11:08:27 AM UnLock
9/6/2018 11:08:28 AM SortPreferenceSets
9/6/2018 11:08:28 AM - Default ManooM
9/6/2018 11:08:28 AM TOracleQuery $0670AD00 Start Query.Execute
9/6/2018 11:08:28 AM TOracleQuery $0670AD00 End (0 records processed)
Duration = 0.063
Duration = 0.062
9/6/2018 11:08:29 AM Lock
9/6/2018 11:08:29 AM UnLock
9/6/2018 11:08:29 AM DoUpdateChildList
9/6/2018 11:08:29 AM FormActivate start
9/6/2018 11:08:29 AM FormActivate end
9/6/2018 11:08:29 AM WMUpdatePopups starts
9/6/2018 11:08:29 AM Adding new connection
9/6/2018 11:08:29 AM Username =
9/6/2018 11:08:29 AM Database = itdbs_kerb
9/6/2018 11:08:29 AM Database = ITDBT_KERB
9/6/2018 11:08:29 AM LoadDesktop starts
9/6/2018 11:08:29 AM TOracleQuery Query Start Query.Execute
9/6/2018 11:08:29 AM TOracleQuery Query End (5 records processed)
Duration = 0.031
9/6/2018 11:08:29 AM SessionChanged SetDBAViews
9/6/2018 11:08:29 AM TOracleQuery $0670AD00 Start Query.Execute
9/6/2018 11:08:29 AM TOracleQuery $0670AD00 End (0 records processed)
Duration = 0.031
Duration = 0.047
9/6/2018 11:08:29 AM TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
:N = Null
9/6/2018 11:08:29 AM TOracleQuery PLSQLDevForm.DynamicQuery End
Duration = 0.016
9/6/2018 11:08:29 AM SessionChanged Authorizations.Load
9/6/2018 11:08:29 AM SessionChanged ApplyPreferences
9/6/2018 11:08:30 AM SortPreferenceSets
9/6/2018 11:08:30 AM - Default ManooM
9/6/2018 11:08:30 AM SessionChanged EnableAuthorizedMenus
9/6/2018 11:08:30 AM WindowAllowed(1)
9/6/2018 11:08:30 AM WindowAllowed done
9/6/2018 11:08:30 AM ExecuteConnectScript starts
9/6/2018 11:08:30 AM TOracleQuery $0670AD00 Start Query.Execute
9/6/2018 11:08:30 AM TOracleQuery $0670AD00 End
Duration = 0.016
Duration = 0.016
Duration = 0.016
9/6/2018 11:08:30 AM ExecuteConnectScript ends
9/6/2018 11:08:30 AM SetSessionAction starts: Primary Session
9/6/2018 11:08:30 AM TOracleQuery $0670AD00 End (1 record processed)
Duration = 0.047
Duration = 0.016
9/6/2018 11:08:30 AM SetSessionAction ends
9/6/2018 11:08:30 AM SessionChanged LoadRecentObjects
9/6/2018 11:08:30 AM SessionChanged Notify children
9/6/2018 11:08:30 AM SessionChanged Logoff secondary sessions
9/6/2018 11:08:30 AM SessionChanged EnableChildFunctions
9/6/2018 11:08:30 AM Lock
9/6/2018 11:08:30 AM UnLock
9/6/2018 11:08:30 AM LoadDesktop ends
9/6/2018 11:08:30 AM FindPassword starts for @itdbs_kerb
9/6/2018 11:08:30 AM Check current connections...
9/6/2018 11:08:30 AM Checking @itdbs_kerb...
9/6/2018 11:08:30 AM Checking @ITDBT_KERB...
9/6/2018 11:08:30 AM Check connection definitions...
9/6/2018 11:08:30 AM FindPassword ends for @itdbs_kerb, no result
9/6/2018 11:08:30 AM FindPassword starts for @ITDBT_KERB
9/6/2018 11:08:30 AM FindPassword ends for @ITDBT_KERB, no result
9/6/2018 11:08:30 AM WMUpdatePopups ends
Will there be any updates to this thread? Are there better channels to get support? I would really like to run the query builder.
