PLD start up with Recent menu etc. and not 'normal' logon dialog
Claus Pedersen
During testing of the beta versions of version 15, the 'normal' logon dialog (Username, Password, Database, Connect as etc.) was replaced by a menu (Imported Fixed Users, Imported History, Recent, and with an Other button) when starting the PLD program.
How do I get the 'normal' logn dialog back in version 15 (where I can use Ctrl-H or the ellipsis to recall the history)?
I am using version 15.0.0.2050
it seems "noconnectionlist" parameter helps. try to find it in params.ini and Manual.pdf.
it was correct for versions prior to 15, maybe for 15 too, who knows?.. :)
Thanks, lost
It seems that using the parameter when calling PLD:
plsqldev.exe noconnectionlist
did the trick.
I could not find anything in the ini files, nor the manual, other than the noconnectionlist switch, but it works and I am back to the 'normal' behaviour
