Here it is
PL/SQL Developer
Version 8.0.3.1510
Physical memory : 2,097,152 kB (692,100 available)
Paging file : 4,194,304 kB (2,864,984 available)
Virtual memory : 2,097,024 kB (2,031,072 available)
Parameters
P:\PLSQL Developer\plsqldev.exe
queryhints
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
23-Apr-2010 14:31:50 Application started
23-Apr-2010 14:31:50 InitPreferences
23-Apr-2010 14:31:50 Load P:\PLSQL Developer\Preferences\Default = 0
23-Apr-2010 14:31:50 PreferenceSet.Load P:\PLSQL Developer\Preferences\Default\Default.ini
23-Apr-2010 14:31:50 PreferenceSet.Load OK
23-Apr-2010 14:31:50 Determine LocalPrefPath
23-Apr-2010 14:31:50 [1]: P:\PLSQL Developer\Preferences
23-Apr-2010 14:31:50 LocalPrefPath: P:\PLSQL Developer\Preferences\harkness
23-Apr-2010 14:31:50 Load P:\PLSQL Developer\Preferences\harkness = 0
23-Apr-2010 14:31:50 PreferenceSet.Load P:\PLSQL Developer\Preferences\harkness\default.ini
23-Apr-2010 14:31:50 PreferenceSet.Load P:\PLSQL Developer\Preferences\harkness\user.prefs
23-Apr-2010 14:31:50 InitPreferences end
23-Apr-2010 14:31:50 SortPreferenceSets
23-Apr-2010 14:31:50 - Default harkness
23-Apr-2010 14:31:50 - System Default
23-Apr-2010 14:31:50 pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
23-Apr-2010 14:31:50 ReadString OK
23-Apr-2010 14:31:50 pfReadRegistry: "C:\Program Files\PLSQL Developer\PLSQLDev.exe" "%1"
23-Apr-2010 14:31:50 LoadPreferences
23-Apr-2010 14:31:50 LoadPreferences searching for default
23-Apr-2010 14:31:50 P:\PLSQL Developer\Preferences\harkness\default.ini
23-Apr-2010 14:31:50 LoadPreferences NewPref := nil
23-Apr-2010 14:31:50 LoadPreferences Reading preferences
23-Apr-2010 14:31:50 LoadPreferences ReadPosition
23-Apr-2010 14:31:50 LoadPreferences ToolsBrowserItemClick(nil)
23-Apr-2010 14:31:50 LoadPreferences CreateBrowserFilters...
23-Apr-2010 14:31:50 LoadPreferences Files
23-Apr-2010 14:31:50 LoadPreferences Logon
23-Apr-2010 14:31:50 LoadPreferences Buttons
23-Apr-2010 14:31:50 LoadPreferences Printer
23-Apr-2010 14:31:50 LoadPreferences FileBrowserFolders
23-Apr-2010 14:31:50 LoadPreferences BrowserFolders
23-Apr-2010 14:31:50 LoadPreferences end
23-Apr-2010 14:31:50 MacroLibFilename: P:\plsqldev\harkness.lib
23-Apr-2010 14:31:50 FormCreate Logon.Execute
23-Apr-2010 14:31:55 TOracleSession PLSQLDevForm.Session Start Session.LogOn as ddlsuser@rwhse
23-Apr-2010 14:31:55 TOracleQuery BytesPerCharacterQuery Start Query.Execute
23-Apr-2010 14:31:55 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0
23-Apr-2010 14:31:55 TOracleQuery Query Start Query.Execute
23-Apr-2010 14:31:55 TOracleQuery Query End (1 record processed)
Duration = 0
23-Apr-2010 14:31:55 TOracleSession PLSQLDevForm.Session End
Duration = 0.172
23-Apr-2010 14:31:55 FormCreate Session.Connected
23-Apr-2010 14:31:55 FormCreate Logon.Executed -1
23-Apr-2010 14:31:55 FormCreate TDBNames.Make
23-Apr-2010 14:31:55 FormCreate SessionChanged
SQL = select * from v$version
23-Apr-2010 14:31:55 TOracleQuery Query End (5 records processed)
Duration = 0.016
23-Apr-2010 14:31:55 SessionChanged SetDBAViews
23-Apr-2010 14:31:55 TOracleQuery $02C9C170 Start Query.Execute
23-Apr-2010 14:31:55 TOracleQuery $02C9C170 End (0 records processed)
Duration = 0.031
Duration = 0
23-Apr-2010 14:31:55 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select object_name from sys.dba_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
23-Apr-2010 14:31:55 TOracleQuery PLSQLDevForm.DynamicQuery End (50 records processed)
Duration = 0
23-Apr-2010 14:31:55 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Next for up to 50 records
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.015
23-Apr-2010 14:31:55 TOracleQuery PLSQLDevForm.DynamicQuery End (35 records processed)
Duration = 0
23-Apr-2010 14:31:55 TOracleQuery $02C9C170 Start Query.Describe
SQL = select * from sys.dba_objects where rownum < 1
Duration = 0
SQL = select * from sys.dba_tab_columns where rownum < 1
Duration = 0.032
SQL = select * from sys.dba_col_comments where rownum < 1
Duration = 0.015
SQL = select * from sys.dba_triggers where rownum < 1
Duration = 0.063
SQL = select * from sys.dba_constraints where rownum < 1
Duration = 0.015
SQL = select * from sys.dba_indexes where rownum < 1
Duration = 0.032
SQL = select * from sys.dba_cons_columns where rownum < 1
Duration = 0.015
SQL = select * from sys.dba_ind_columns where rownum < 1
Duration = 0.047
SQL = select * from sys.dba_dependencies where rownum < 1
Duration = 0.015
23-Apr-2010 14:31:55 TOracleQuery $02C9C010 Start Query.Describe
SQL = select * from sys.dba_tables where rownum < 1
23-Apr-2010 14:31:56 TOracleQuery $02C9C010 End
Duration = 0.016
23-Apr-2010 14:31:56 TOracleQuery $02C9C010 Start Query.Describe
SQL = select * from sys.dba_tab_comments where rownum < 1
Duration = 0
SQL = select * from sys.dba_sequences where rownum < 1
Duration = 0
23-Apr-2010 14:31:56 TOracleQuery $02C9C170 Start Query.Describe
SQL = select * from sys.dba_errors where rownum < 1
23-Apr-2010 14:31:56 TOracleQuery $02C9C170 End
Duration = 0.016
SQL = select * from sys.dba_source where rownum < 1
Duration = 0
SQL = select * from sys.dba_views where rownum < 1
Duration = 0.015
SQL = select * from sys.dba_synonyms where rownum < 1
Duration = 0
SQL = select * from sys.dba_users where rownum < 1
Duration = 0.032
SQL = select * from sys.dba_object_tables where rownum < 1
Duration = 0.047
SQL = select * from sys.dba_type_attrs where rownum < 1
Duration = 0.046
SQL = select * from sys.dba_type_methods where rownum < 1
Duration = 0.016
SQL = select * from sys.dba_method_params where rownum < 1
Duration = 0.031
SQL = select * from sys.dba_method_results where rownum < 1
Duration = 0.032
SQL = select * from sys.dba_tab_privs where rownum < 1
Duration = 0.016
SQL = select * from sys.dba_clusters where rownum < 1
Duration = 0.031
SQL = select * from sys.dba_libraries where rownum < 1
Duration = 0
SQL = select * from sys.dba_directories where rownum < 1
Duration = 0
SQL = select * from sys.dba_jobs where rownum < 1
Duration = 0
SQL = select * from sys.dba_db_links where rownum < 1
Duration = 0.015
SQL = select * from sys.dba_mviews where rownum < 1
Duration = 0.016
SQL = select * from sys.dba_snapshots where rownum < 1
Duration = 0
SQL = select * from sys.dba_queues where rownum < 1
Duration = 0.016
SQL = select * from sys.dba_queue_tables where rownum < 1
Duration = 0.015
SQL = select * from sys.dba_types where rownum < 1
Duration = 0.031
SQL = select * from sys.dba_scheduler_jobs where rownum < 1
Duration = 0.125
SQL = select * from sys.dba_scheduler_program_args where rownum < 1
Duration = 0.063
SQL = select * from sys.dba_scheduler_job_args where rownum < 1
Duration = 0.016
SQL = select * from sys.dba_scheduler_wingroup_members where rownum < 1
Duration = 0
SQL = select * from sys.dba_scheduler_windows where rownum < 1
Duration = 0.015
23-Apr-2010 14:31:56 SessionChanged Authorizations.Load
23-Apr-2010 14:31:56 TOracleQuery $02C9C170 Start Query.Execute
sys.plsqldev_authorization
Duration = 0.016
23-Apr-2010 14:31:56 SessionChanged EnableAuthorizedMenus
23-Apr-2010 14:31:56 ExecuteConnectScript starts
SQL = alter session set plsql_optimize_level = 2
Duration = 0
SQL = alter session set plsql_code_type = interpreted
Duration = 0
23-Apr-2010 14:31:56 ExecuteConnectScript ends
23-Apr-2010 14:31:56 TOracleQuery $02C9C170 End (1 record processed)
Duration = 0
23-Apr-2010 14:31:56 TOracleSession $02CDCD90 Start Session.LogOn as ddlsuser@rwhse
23-Apr-2010 14:31:56 TOracleQuery Query Start Query.Execute
23-Apr-2010 14:31:56 TOracleQuery Query End (1 record processed)
Duration = 0.016
23-Apr-2010 14:31:56 TOracleSession $02CDCD90 End
Duration = 0.094
23-Apr-2010 14:31:56 SetSessionAction starts: Main session
23-Apr-2010 14:31:56 TOracleQuery $02C9C010 Start Query.Execute
SQL = select null from dual
23-Apr-2010 14:31:56 TOracleQuery BytesPerCharacterQuery Start Query.Execute
23-Apr-2010 14:31:56 TOracleQuery $02C9C010 End (1 record processed)
Duration = 0
23-Apr-2010 14:31:56 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
:ACTION = Main session
Duration = 0
23-Apr-2010 14:31:56 TOracleQuery $02C9C2D0 Start Query.Execute
from sys.all_objects o
where o.owner = :schema and o.object_type in ('TABLE', 'VIEW', 'PACKAGE','TYPE', 'PROCEDURE', 'FUNCTION', 'SEQUENCE')
:SCHEMA = DDLSUSER
Duration = 0.015
23-Apr-2010 14:31:56 SetSessionAction ends
23-Apr-2010 14:31:56 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
23-Apr-2010 14:31:56 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
23-Apr-2010 14:31:56 SessionChanged LoadRecentObjects
23-Apr-2010 14:31:56 SessionChanged Notify children
23-Apr-2010 14:31:56 SessionChanged Logoff secondary sessions
23-Apr-2010 14:31:56 SessionChanged SessionMode = smMulti
SQL = select /*+rule*/ value from v$nls_parameters where parameter = 'NLS_DATE_FORMAT'
Duration = 0
23-Apr-2010 14:31:56 SessionChanged EnableChildFunctions
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient10g_home2
OracleHomeDir: C:\oracle\product\10.2.0\client_2
Found: oci.dll
Using: C:\oracle\product\10.2.0\client_2\bin\oci.dll
SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
Duration = 0
23-Apr-2010 14:31:56 TOracleQuery $02C9C2D0 End (0 records processed)
Duration = 0.063
from all_synonyms s,
sys.all_objects o
where s.owner in ('PUBLIC', :schema)
and o.owner = s.table_owner
:SCHEMA = DDLSUSER
23-Apr-2010 14:31:56 PlugIn Exception: "Favorites v2.1" OnCreate
23-Apr-2010 14:31:57 TOracleQuery $02C9C2D0 End (100 records processed)
Duration = 0.782
23-Apr-2010 14:31:57 TOracleQuery $02C9C2D0 Start Query.Next for up to 100 records
Duration = 0.015
Duration = 0
23-Apr-2010 14:31:57 SortPreferenceSets
Duration = 0.078
23-Apr-2010 14:31:57 - Default harkness
23-Apr-2010 14:31:57 - System Default
Duration = 0
Duration = 0.016
Duration = 0.016
Duration = 0
23-Apr-2010 14:31:57 TOracleQuery $02C9C010 Start Query.Execute
23-Apr-2010 14:31:57 TOracleQuery $02C9C010 End (0 records processed)
Duration = 0
Duration = 0
Duration = 0.031
Duration = 0.047
Duration = 0.031
Duration = 0
Duration = 0.016
Duration = 0.015
23-Apr-2010 14:31:57 FormActivate start
23-Apr-2010 14:31:58 FormActivate end
23-Apr-2010 14:31:58 WMUpdatePopups starts
23-Apr-2010 14:31:58 LoadFileList: C:\DOCUME~1\harkness\LOCALS~1\Temp\PLS-Recovery\*.cfg
23-Apr-2010 14:31:58 LoadFileList 4 items
23-Apr-2010 14:31:58 LoadFileList DateSort
23-Apr-2010 14:31:58 GetCrashList: 2825000.cfg
23-Apr-2010 14:31:58 GetCrashList: 3410034.cfg
23-Apr-2010 14:31:58 GetCrashList: 18875204.cfg
23-Apr-2010 14:31:58 GetCrashList: 2754298.cfg
23-Apr-2010 14:31:58 LoadDesktop starts
23-Apr-2010 14:31:58 DoUpdateChildList
23-Apr-2010 14:31:58 LoadDesktop ends
23-Apr-2010 14:31:58 WMUpdatePopups ends
23-Apr-2010 14:31:59 TOracleQuery $02C9C2D0 End (100 records processed)
Duration = 1.844
23-Apr-2010 14:31:59 TOracleQuery $02C9C2D0 Start Query.Next for up to 100 records
23-Apr-2010 14:32:00 TOracleQuery $02C9C2D0 End (100 records processed)
Duration = 0.828
23-Apr-2010 14:32:00 TOracleQuery $02C9C2D0 Start Query.Next for up to 100 records
23-Apr-2010 14:32:03 ExecuteTemplateByName: PROGRAM UNITS\&Program Window
23-Apr-2010 14:32:03 ExecuteTemplate: P:\PLSQL Developer\Template\PROGRAM UNITS\&Program Window.tpl
23-Apr-2010 14:32:03 Path: P:\PLSQL Developer\Template\PROGRAM UNITS\&Program Window.tpl
23-Apr-2010 14:32:04 TOracleQuery $02C9C2D0 End (100 records processed)
Duration = 4.297
23-Apr-2010 14:32:04 TOracleQuery $02C9C2D0 Start Query.Next for up to 100 records
Duration = 0.015
Duration = 0.016
Duration = 0
23-Apr-2010 14:32:05 TOracleQuery $02C9C2D0 Start Query.Next for up to 100 records
23-Apr-2010 14:32:05 TOracleQuery $02C9C2D0 End (100 records processed)
Duration = 0.015
Duration = 0.016
Duration = 0.015
Duration = 0.016
Duration = 0.063
23-Apr-2010 14:32:05 TOracleQuery $02C9C2D0 End (13 records processed)
Duration = 0.281
23-Apr-2010 14:32:05 TOracleSession $02CDCD90 Start Session.LogOff
23-Apr-2010 14:32:05 TOracleSession $02CDCD90 End
Duration = 0
23-Apr-2010 14:32:05 Create TCommandForm Start
23-Apr-2010 14:32:05 Create TCommandForm Inherited
23-Apr-2010 14:32:05 Create TCommandForm SetupMainFont
23-Apr-2010 14:32:05 Create TCommandForm Activate
23-Apr-2010 14:32:05 Create TCommandForm Activate done
23-Apr-2010 14:32:05 Create TCommandForm UpdateWindowList
23-Apr-2010 14:32:05 UpdateChildList [timer]
23-Apr-2010 14:32:05 Create TCommandForm Positioning
23-Apr-2010 14:32:05 Create TCommandForm Finished
23-Apr-2010 14:32:05 TOracleQuery Query Start Query.Execute
23-Apr-2010 14:32:05 TOracleQuery Query End (5 records processed)
Duration = 0
Duration = 0
23-Apr-2010 14:32:05 NavigationBookmarks.EnableButtons(Rebuild)
23-Apr-2010 14:32:05 NavigationBookmarks: Backward=0, Forward=0
23-Apr-2010 14:32:05 ExecuteTemplateByName: Default\Command Window
23-Apr-2010 14:32:05 ExecuteTemplate: P:\PLSQL Developer\Template\Default\Command Window.tpl
23-Apr-2010 14:32:05 Path: P:\PLSQL Developer\Template\Default\Command Window.tpl
23-Apr-2010 14:32:05 InterpretLine starts: -- Autostart Command Window script
23-Apr-2010 14:32:05 InterpretLine ends
23-Apr-2010 14:32:05 InterpretLine starts: set sqlprompt [connection]
23-Apr-2010 14:32:05 DoUpdateChildList
23-Apr-2010 14:32:21 TOracleQuery $02C9BEB0 Start Query.Execute
23-Apr-2010 14:32:21 TOracleQuery $02C9BEB0 End (1 record processed)
Duration = 0
23-Apr-2010 14:32:21 TOracleQuery PLSQLDevForm.ResolveSymbolQuery2 Start Query.Execute
SQL = declare
c integer := 0;
p1 varchar2(500);
p2 varchar2(500);
expr varchar2(500);
dblink varchar2(500);
part1_type integer;
object_number integer;
dp integer;
bject_type := null;
bject_owner := null;
bject_name := null;
:sub_object := null;
expr :=
art1;
if
art2 is not null then expr := expr || '.' ||
art2; end if;
if
art3 is not null then expr := expr || '.' ||
art3; end if;
loop
sys.dbms_utility.name_resolve(name => expr,
context => c,
schema =>
bject_owner,
part1 => p1,
part2 => p2,
dblink => dblink,
part1_type => part1_type,
object_number => object_number);
if part1_type = 1 then
bject_type := 'INDEX'; end if;
if part1_type = 2 then
bject_type := 'TABLE'; end if;
if part1_type = 4 then
bject_type := 'VIEW'; end if;
if part1_type = 5 then
bject_type := 'SYNONYM'; end if;
if part1_type = 6 then
bject_type := 'SEQUENCE'; end if;
if part1_type = 7 then
bject_type := 'PROCEDURE'; end if;
if part1_type = 8 then
bject_type := 'FUNCTION'; end if;
if part1_type = 9 then
bject_type := 'PACKAGE'; end if;
if part1_type = 12 then
bject_type := 'TRIGGER'; end if;
if part1_type = 13 then
bject_type := 'TYPE'; end if;
if part1_type = 28 then
bject_type := 'JAVA SOURCE'; end if;
if part1_type = 29 then
bject_type := 'JAVA CLASS'; end if;
if
bject_type is null then
select object_type into
bject_type
where object_id = object_number;
end if;
exception
when others then null;
c := c + 1;
if c > 9 then
dp := instr(expr, '.', -1);
if dp > 0 then
if :sub_object is not null then
:sub_object := '.' || :sub_object;
end if;
:sub_object := upper(substr(expr, dp + 1)) || :sub_object;
expr := substr(expr, 1, dp - 1);
c := 0;
end if;
end if;
exit when
object_type is not null) or (c > 9);
end loop;
if
bject_type is not null then
if p1 is null then
bject_name := p2;
elsif p2 is null then
bject_name := p1;
if
bject_name =
art1 and
:sub_object :=
art2;
end if;
if
bject_name =
art2 and
:sub_object :=
art3;
end if;
else
bject_name := p1;
:sub_object := p2;
end if;
return;
end if;
if
art2 is null and
art3 is null then
select 'USER', null,
art1
into
bject_type,
bject_owner,
bject_name
from sys.dba_users u
where u.username =
art1
and rownum = 1;
return;
end if;
exception
when no_data_found then
null;
if
art2 is null and
art3 is null and :deep != 0 then
select 'ROLE', null,
art1
into
bject_type,
bject_owner,
bject_name
from sys.session_roles r
where r.role =
art1
and rownum = 1;
return;
end if;
exception
null;
if :deep != 0 then
if
art2 is null then
into
bject_type,
bject_owner,
bject_name
from sys.dba_constraints c
where c.constraint_name =
art1
and c.owner = :cur_schema
and rownum = 1;
else
select constraint_type, owner, constraint_name,
art3
into
bject_type,
bject_owner,
bject_name, :sub_object
art2
and c.owner =
art1
and rownum = 1;
end if;
if
bject_type = 'P' then
bject_type := 'PRIMARY KEY';
end if;
if
bject_type = 'U' then
bject_type := 'UNIQUE KEY';
end if;
if
bject_type = 'R' then
bject_type := 'FOREIGN KEY';
end if;
if
bject_type = 'C' then
bject_type := 'CHECK CONSTRAINT';
end if;
return;
exception
null;
end if;
ART1 = APPPNLADMIN
:OBJECT_TYPE = Null
:OBJECT_OWNER = Null
:OBJECT_NAME = Null
ART2 =
:SUB_OBJECT = Null
ART3 =
EEP = 0
:CUR_SCHEMA = DDLSUSER
23-Apr-2010 14:32:21 TOracleQuery PLSQLDevForm.ResolveSymbolQuery2 End
Duration = 0.047
23-Apr-2010 14:32:21 TOracleQuery PLSQLDevForm.UserObjectsQuery Start Query.Execute
SQL = select /*+rule*/ object_name synonym_name, object_name, owner object_owner, status, object_type
from sys.dba_objects o
where o.owner =
bject_owner
and o.object_type in ('TABLE', 'VIEW', 'MATERIALIZED VIEW', 'SEQUENCE', 'FUNCTION', 'PROCEDURE', 'PACKAGE', 'TYPE')
and o.object_name not like 'BIN$%'
order by o.object_type, o.object_name
:OBJECT_OWNER = APPPNLADMIN
:OBJECT_TYPE = 'TABLE', 'VIEW', 'MATERIALIZED VIEW', 'SEQUENCE', 'FUNCTION', 'PROCEDURE', 'PACKAGE', 'TYPE'
:EXTRA_CONDITION = Null
23-Apr-2010 14:32:21 TOracleQuery PLSQLDevForm.UserObjectsQuery End (25 records processed)
Duration = 0.031
23-Apr-2010 14:32:21 TOracleQuery PLSQLDevForm.UserObjectsQuery Start Query.Next for up to 25 records
Duration = 0
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
23-Apr-2010 14:32:21 TOracleQuery PLSQLDevForm.UserObjectsQuery End (14 records processed)
Duration = 0
23-Apr-2010 14:32:42 InterpretLine starts: desc apppnladmin.pnl_position
23-Apr-2010 14:32:42 TOracleQuery $02C9BEB0 Start Query.Execute
23-Apr-2010 14:32:42 TOracleQuery $02C9BEB0 End (1 record processed)
Duration = 0
23-Apr-2010 14:32:42 TOracleQuery PLSQLDevForm.ResolveSymbolQuery2 Start Query.Execute
SQL = declare
c integer := 0;
p1 varchar2(500);
p2 varchar2(500);
expr varchar2(500);
part1_type integer;
dp integer;
bject_type := null;
bject_name := null;
expr :=
art1;
if
art2; end if;
if
art3; end if;
loop
context => c,
schema =>
bject_owner,
part1 => p1,
part2 => p2,
dblink => dblink,
if
bject_type
end if;
exception
c := c + 1;
if c > 9 then
if dp > 0 then
end if;
c := 0;
end if;
end if;
exit when
end loop;
if
if p1 is null then
bject_name := p2;
bject_name := p1;
if
bject_name =
art1 and
:sub_object :=
art2;
end if;
if
bject_name =
art2 and
:sub_object :=
art3;
end if;
else
bject_name := p1;
:sub_object := p2;
end if;
return;
end if;
if
art2 is null and
art3 is null then
art1
into
bject_type,
bject_owner,
bject_name
where u.username =
art1
and rownum = 1;
return;
end if;
exception
null;
if
art2 is null and
art1
into
bject_type,
bject_owner,
bject_name
where r.role =
art1
and rownum = 1;
return;
end if;
exception
null;
if :deep != 0 then
if
art2 is null then
into
bject_type,
bject_owner,
bject_name
art1
and rownum = 1;
else
art3
into
bject_type,
bject_owner,
art2
and c.owner =
art1
and rownum = 1;
end if;
if
end if;
if
end if;
if
end if;
if
end if;
return;
exception
null;
end if;
ART1 = APPPNLADMIN
:OBJECT_TYPE = USER
:OBJECT_NAME = APPPNLADMIN
ART2 = PNL_POSITION
:SUB_OBJECT = Null
ART3 =
EEP = 0
23-Apr-2010 14:32:42 TOracleQuery PLSQLDevForm.ResolveSymbolQuery2 End
Duration = 0
23-Apr-2010 14:32:42 InterpretLine ends
23-Apr-2010 14:32:42 NavigationBookmarks.EnableButtons(Rebuild)
23-Apr-2010 14:32:42 NavigationBookmarks: Backward=0, Forward=0
