debugging loop variable
sthaler
When I use the same loop variable in a second (not nestet) loop the debugger displays in the second loop the value from the fist loop, but it is using correctly the second one.
Example:
-- first loop
for i in 1 .. 4 loop
end loop;
-- second loop
for i in 1 .. 4
-- Debugger display i = 4
end loop;
Is it better to use always different names i1, i2...)?
Sepp Thaler
The Oracle Debug API does indeed get confused when using the same variable for different for-loops. For debugging purposes it would be a good idea to use unique variables for each loop like you suggest.
