In version 9.0.2.1621 debugger has a problem, which can be reproduced as follows:
1. Log on with user which does not have any debug privileges (debug connect session or debugging any procedure).
2. Open Test Script window, enter some valid SQL-script and try to start debugging. The error about privileges will appear.
3. Now menu item Debug -> Start is disabled and you cannot try to start debugging once more, even if privileges are already granted.
