Ctrl-F and F&R dialog
Wim
carabazz said:
1. Ctrl-F keystroke does not work
Even though I reset the key configurations to default, ctrl-f is not working for me. I'll test some more and get back to you all.
When using the button in the menu to launch the Find&Replace window I also get the following:
- the (dropdown-)field for "Text to find" is not 'active', meaning I can't start typing immediately
- if I try to use the keyboard with Alt-T to make this field active ("T" in "Text to find" is underlined) the F&R dialog disappears and the Tools menu opens ..
I cannot reproduce either issue. Can you check if the Edit > Find & Replace menu item shows the Ctrl+F shortcut?
The issue with ctrl-f has been solved; I too had a custom preference set that I didn't update for ctrl-f.
The other issue seems to be gone as well!
It seems to me that it is not possible to navigate through the find&replace-window using the TAB-Key. The short-cuts (like Alt-E for "Replace with") won't work either.
Is that problem reproducable? I have that issue on two different machines.
Thanks for help,
Hannes
PS: The short-cuts don't work if they are assigned to the menu as well
Okay... the TAB-Key issue comes up due to my own shortcut-definitions as well. But why are they active in the find&replace window? That makes no sense - at least from my point of view.
The other issue should be easily solvable. Either you just define Unique Alt--shortcuts or the active window is "served" first - should be possible, right?
Thanks in advance (especially if it would be possible to just ignore userdefined shortcuts that are used for basic functionality in the find&replace Window),
Hannes
We'll check it out. Your own shortcut definitions work because the Find&Replace dialog is a modeless dialog (all other PL/SQL Developer functionality is available).
