crazy error - PL/SQL Dev 10.0.5.1710
boaglio
We have been facing a strange error which a column name changes and if you try to compile inside Program Window, it does not show the yellow bar with the error line... just a very small text Compiled with errors =(
Running inside command window:
SQL> alter package pac001 compile;
Warning: Package altered with compilation errors
SQL> show errors
Errors for PACKAGE ADM.pac001:
LINE/COL ERROR
63/1     PLS-00920: parameter plsql_native_library_dir is not set
SQL>
Running inside SQL* Plus:
SQL>alter package pac001 compile;
SQL>show errors
Erros para PACKAGE BODY pac001:
LINE/COL ERROR
3091/5   PL/SQL: SQL Statement ignored
3099/12  PL/SQL: ORA-00904: "A"."ID_COLUNA"
4183/5   PL/SQL: SQL Statement ignored
4287/7   PL/SQL: ORA-00984: column not allowed here
SQL>
I am not sure if this wrong behavior is related to PL/SQL type code (Native or Interpreted)... using both values come up with the same result.
Is there any work around for this ?
My team is switching back to another dev tool for this :(
I assume there is no line associated with the PLS-00920 error.
Can you go to Tools > Preferences > Oracle / Compiler and set the "PL/SQL Code type" option to "Interpreted"? Verify if this helps.
I have tried both options... still same error =(
We were using Oracle 10.2 Driver and today I tried with 11.2, still same behavior.
The line 63 mentioned above is just a single variable declaration:
v_exists          varchar2(1) := 'Y';
Maybe this is an 64 bits issue... but is there any workaround for it ?
Do you still get PLS-00920? If so, then to obtain some more diagnostic information, can you modify the shortcut and add the DebugSQL parameter? For example:
Thanks. I still see this statement in the log file:
alter session set plsql_code_type = native
This indicates that the "PL/SQL Code type" preference is still set to "Native" instead of "Interpreted". Can you double-check?
The first log it was "Native" with client "Oracle 11i".
I've created another one, with "Interpreted" and client "Oracle 10g":
http://pastebin.com/BEvmdiEU
All four combinations got the same result:
"Native" + "Oracle 11i".
"Native" + "Oracle 10g".
"Interpreted" + "Oracle 10g"
"Interpreted" + "Oracle 11i"
Hi, Fernando!
Have you tried commenting some code around line 63? I've faced this issue before, but the parser/compiler was getting lost and pointing to the wrong line.
Regards,
Gustavo
Since in SQL*Plus is working fine, it proves that this issue is _not_ related to code error.
It should be something related to processor arch, since is an 64 bits error only.
