Copy SQL from SQL Window with Connection Indicators
gareth_moore
When I copy SQL from a SQL window with a coloured connection indicator and paste it into a rich text editor like Outlook, the colour appears in the spaces in between the text.
Is it possible to exclude the colour from the connection indicator from a text copy?
We'll fix this. At the moment you can only disable the "Include font style with copy" preference (Tools > Preferences > User Interface / Fonts), but this will remove all syntax highlighting and font information.
This has reappeared in the 64-bit version. Is this likely to be fixed as I am using the 64-bit version as my main application and it's a bit annoying having to use the 32-bit version when I want to copy text.
