In ver 16 (just moved from ver 14), the context menu for the known objects has the most used options in a submenu ... really?
I rarely/never use the first options proposed (in the attached picture in red) in the menu and I have to move the mouse quite a bit to find the option I actually intend to use (in green).
Can the menu be re-arranged a bit?
P.S. Can the drop option be moved down a bit, especially with the packages? Is just below the Edit, which is the most used option I use
