Contents-List in Package Body not visible when using $$PLSQL_UNIT
Cartaz
when a variable is declared with $$PLSQL_UNIT as the last variable in the Declaration part of an function or procedure the Methodtree (Contents) of the Package Body is not visible.
(The rest of the Code will be handeled as a "Comment"?).
If it is at first position or in between it works fine.
CREATE OR REPLACE PACKAGE pa_test IS
PROCEDURE p_test1;
PROCEDURE p_test2;
END;
CREATE OR REPLACE PACKAGE BODY pa_test
IS
PROCEDURE p_test1
IS
--x VARCHAR2(200);
methodname VARCHAR2(200) := $$PLSQL_UNIT||'.p_test1';
--y VARCHAR2(200);
NULL;
END p_test1;
PROCEDURE p_test2
IS
methodname VARCHAR2(200) := $$PLSQL_UNIT||'.p_test2';
--x VARCHAR2(200);
NULL;
END p_test2;
END;
