I have two Preference Sets: one default and one that has wildcards set up for certain connections. This second preference set uses a different color scheme.
When I change the main connection and a different preference set gets applied, the Connections panel behaves oddly. The folders and connections in it remain the same, but which folders are expanded/collapsed and which connection is currently selected changes. Frequently I collapse most folders and double-click the connection I want, only to have everything expanded, including the "Recent" folder", and scrolled out of view.
Can you please find the bit of code that re-organizes the Connections panel when the Preference Set is switched, and turn it off?
Thank you.
