When I open a Oracle package (View or Edit of Spec & Body), if there are compile errors it used to list the errors and on selecting these errors(bottom window area) I was able to go to the lines with errors. This used to work fine but stopped working recently. I still get the list of errors listed with line numbers ,just when any of the line is selected, the code highlighting and navigating to the line is no longer happening.
If after open in edit mode if i press compile , then in that mode it works fine again.
Can i have that functionality reinstate of straightaway seeing the error lines please?
Sanj
PL/SQL Developer Version 15.0.3.2059 (64 bit)
Sanj
