Command Window Losses connection - Version 13.0.1.1893 (64 bit)
Felix
Command Window can not change connection, keeps say not logged in. It happens if I type connect user/pass@host or select a different connection from the status bar. If I quit and start the window is pinned and most of the time is not connected.
I have to keep closing the command window and open a new one after I switch connections.
PL-SQL Dev Version 13.0.1.1893 (64 bit)
