Command Window and SQL Window do not display on the "connections" tab
rayma1
I am encountering issue with the Connections tab using version 9.0.6.1665.
Intermittently, when I am logged to multiple databases, new windows that I open such as Command window or SQL window are not appearing on the "Database Connections" list. This issue does not happen on version 9.0.5.1648.
Hi Marco,
Thank you for your responce. I appreciate it.
There is no error being produced but I will try mentioning a scenario. Hopefully this would help.
1. Install the new version by overwriting whatever configuration I have on the older version.
2. I Open up and connected to one of the database. Choose "Connections Tab"
3. On my window, the left side I mostly focused is the "Connections" tab. Under it, I have a list of database connection but currently one is active.
4. Open up a window "command window" by right clicking on the active connection on "Connections" tab.
5. Open up again a window "sql window". Both windows are maximize. result is still ok.
6. This time connect to a new a database by right clicking on the listed database on the "Connections" tab. Now I have 2 active connections but this time the focus was moved to the latest connection.
7. Open up a window by right clicking the latest connection. BOOM!!! That is where the problem surface. The new window opens up but the icon (+) sign does not appear on the "Connections Tab" for the latest opened database connection. Usually, there is an icon (+) plus sign that you can click to list down the windows open on a specific database connection. Any new database connections make will not show the plus (+) sign anymore when you open a window.
Basically, the problem is that the (+) icon disapears on any connections you make. I am still able to open any windows but it is not listed on the new connections.
Hopefully, I was able to give you a logical scenario.
Regards.
No, we do not seem to be able to create this situation. We'll have a public beta for version 10 shortly. Perhaps you can check if it still happens with this version when it becomes available?
Wow.
Great JOB in supporting my concern. I requested this from our manager to purchase this software and trying to present the good thing about this but my problem was not resolve and now a new version came out requiring to buy a service contract.
Very disappointed. I will just stop promoting this to my co-developer and might as well talk to them to add me to the user of TOAD.
Thanks anyway...
