Code completion errors with ORA-00942
Gustavo
When I try to use code completion I get the following error:
ORA-06550: line 121, column 16:
PL/SQL: ORA-00942: table or view does not exist
ORA-06550: line 119, column 7:
PL/SQL: SQL Statement ignored
This happens when I try to get code completion for something like:
select * from po.
This only happens in production instance. I tried it with "Use DBA views if available" checked and unchecked. I sent a debug.txt that was generated while it was unchecked.
PL/SQL Developer
Version 7.1.5.1397
Regards,
Gustavo
From the error message it would appear that you do not have select privileges on the sys.all_users view. Can you verify this?
Indeed, I get ORA-00942 when I try to select this object. I'm checking with our DBAs for changes over the last weekend. I'll post any findings here.
Thanks!
