1) When using the code assistant to insert function/procedure parameters, the parameter name is followed by " => ". I would like this to be "=>", without spaces, instead. I see that the beautifier also prefers " => ", so perhaps it should be a beautifier option as well.
2) The code assistant does not suggest parameters when the cursor is in the following location:
It would be nice if it would, since it works just fine in these cases:
foo(
foo([#]
foo(
p1=>1,
