Close SQL window: Shift+click vs. right click + Close Window
jure
When closing SQL Window with Shift+click I have to click Yes to close it. On the other hand I have to click No when closing it with right click + Close window.
It would be nice to have the same close dialog for both methods.
Regards,
Jure
In both cases I get the question:
Save changes to SQL Window?
[Yes] [No] [Cancel]
What question do you get for both scenarios?
Marco,
what he means is that if you use Ctrl+click on the window, you get the message "Close Window discarding possible changes Yes/No"
I see. Shift-Click and Right-Click->Close behave the same. Ctrl-Click seems to be an undocumented feature. We'll check it out.
In the mean time, use Shift-Click instead.
Ctrl-Click is a feature that has been implemented not long ago. It is good to easily get rid of small script and test windows, when you choose the option to not have this question asked again.
