M mortalzera Member Jun 29, 2016 #1 I'm trying to set up solarized syntax highlight on the code editor. Is there a way to chose the colors by RGB parameters? Currently the color editor is very poor. Thanks.
Marco Kalter Administrator Staff member Jun 30, 2016 #1 If the custom color selector does not work for you, you can set the RGB values in the preference file: %APPDATA%\PLSQL Developer\Preferences\\default.ini In this file you can find the following lines: KeywordsColor= CommentColor= StringsColor= NumbersColor= SymbolsColor= CustomColor= The is the decimal representation of the RGB value: 65536 * + 256 * + , where , and are a value from 0 .. 255.
William Robertson Member³ Jul 4, 2016 #1 Also see thread What is the encoding used for exporting colour preferences? for an Excel conversion function
