Bug Report – Query Builder does not inherit Dark Theme (Auto Mode)
adrian_star
I would like to report what appears to be a theme-related inconsistency in PL/SQL Developer.
Environment​
  • Color theme mode: Auto
  • System theme: Dark mode (Windows default)
  • PL/SQL Developer correctly inherits the dark theme in main application windows
Issue description​
After enabling and opening the Query Builder module, the window loads using a light theme instead of inheriting the active dark theme from the application.
This results in visual inconsistency within the application.
Expected behavior​
When the theme is set to Auto, and the system is using Dark mode, all application modules — including Query Builder — should consistently inherit and apply the dark theme.
Observations​
  • The main application UI respects the Auto theme setting.
  • The Query Builder appears to ignore it.
  • This suggests that Query Builder may be using a separate or legacy rendering configuration that does not follow the global theme settings.
Impact​
While this is not a functional issue, it affects:
  • UI consistency
  • User experience
  • Accessibility and comfort
Best regards,
Adrian
