PeterW
Use the following code in a program window:
When you fold the for-loop on line 5 (by pressing the minus-sign) and refactor the variable l_dummy to l_dummy2, you get the following result (after unfolding the for-loop):
I encountered similar behaviour with find/replace here.
Version: 8.0.0.1480
create or replace procedure test
is
l_dummy pls_integer;
for i in 1..10
loop
l_dummy := i;
end loop;
end test;
is
l_dummy2 pls_integer;
for i in 1..10
loop
l_dummy := i;
end loop;
end tel_dummy2
Version: 8.0.0.1480
