Claus Pedersen
We have some old code containing tab characters. When using column marking the following sometimes does not work:
Example:
I use colum marking to mark "bbccdd" on both lines.
Now, when I indent, the bb is not indented.
If I mark the same characters again and use Apply Syntax Case, nothing is changed.
I am using version 7.1.5.1397
- indent/unindent: indent leaves the first characters untouched when line contains tabs , unindent also works strangely
- Apply Syntax Case does not work when line contains tabs
Example:
where is the tab character.aabbccdd
aabbccdd
