Claus Pedersen
I have the following code:
I column mark the code after the assignment, i.e columns 10-37, all three rows, and select Edit -> Selection -> Apply Syntax Case.
This is what I get:
Not quite what I expected
I am using the setting Keyword case = Uppercase.
It is the same problem with Remove Trailing Blanks, whereas Uppercase and Lowercase seem to work OK.
value := case when 1=1 then 'x' end;
This is what I get:
value := CASE WHEN 1=1 THEN 'x' END;
CASE WHEN 1=1 THEN 'x' END;value := case when 1=1 then 'x' end;
