Beautifier Error with conditional compling
orca777
Hello Dev-Team,
seems the Beautifier has probs with conditional compiling
this package function - code compiles without error ...
PROCEDURE Set_Creator(
    $IF $$ISS_CORE $THEN
      p_Comid IN Employee.Comid%TYPE
    $ELSE
      p_Comid IN Vxi_Employee.Comid%TYPE
    $END
    ) IS
        Go_Created_By := Employee_Util.Get_Id(p_Comsiid);
    END Set_Creator;
/Karl
PL/SQL-Dev Version 8.0.1.1502
Oracle 10.2.0.3
We'll fix it. As a workaround you can move the parentheses into the conditional expression:
  (p_Comid IN Employee.Comid%TYPE)
  $ELSE
  (p_Comid IN Vxi_Employee.Comid%TYPE)
  $END
   IS
  END Set_Creator;
Thanks Marco;
I know it's not so easy because the preprocessor
does not fit to the parsing tree of the pl/sql-language
for beautifying
thank you for the hint
/Karl
