christianbalz
I receive a message when i execute PL/SQL Beautifier with the code bellow.
Kind regards,
Christian
SELECT CASE BRAN.BRANCH_LEVEL
WHEN 1 THEN
CASE FN_UDF_FUNCID_VALUE('XX','XX', BRAN.BRANCH_CODE )
WHEN '2' THEN 'XXXX'
END
WHEN 2 THEN
WHEN '3' THEN 'XXXX'
WHEN '4' THEN 'XXXX'
END
WHEN 3 THEN
WHEN '5' THEN 'XXXX'
END
WHEN 4 THEN
WHEN '6' THEN 'XXXX'
WHEN '7' THEN 'XXXX'
WHEN '8' THEN 'XXXX'
WHEN '9' THEN 'XXXX'
END
END AS XXX_XXX_XXX
FROM IFVW_BRANCH BRAN
WHERE BRAN.BRANCH_CODE = pi_xxx;
Christian
