Thorsten Kohl (IBS)
Hi, using TPL files is a nice feature. But one problem is, that after replacing the cursor stucks at the beginning of the replaced text. When I use "direct replacements", the cursor moves to the end (behind the replaced text). What can I do, that after replacing the cursor moves to the end of the replaced text?
Example 1:
s*=SELECT * FROM
Result:
"s*" is replace with "SELECT * FROM" and cursor is moved at the end of the replaced text (FROM => cursor).
Example 2:
s*=AutoReplace\select_star_from.tpl
Content of file:
SELECT *
FROM
Result:
"s*" is relaced correctly with
"SELECT *
FROM", but cursor stucks in front of the "SELECT". I have to move cursor manually to the end before I can go on typing.
Thorsten
Example 1:
s*=SELECT * FROM
Result:
Example 2:
Content of file:
SELECT *
FROM
Result:
"SELECT *
Thorsten
