Auto replace with cusor positioning
matejj
I have a feature request:
After auto replace I would like to position cursor to specific position.
For example:
td*= to_date('','dd.mm.yyyy')
and cursor is on the end of new text, but I would like to positon cursor: to_date('here','dd.mm.yyyy')
I don't think this is possible with current functionality?
It is possible when referring to a template in the AutoReplace text. For example, if you have a template folder "SQL Functions" with a template "to_date.tpl" with the following contents:
to_date('[#]','dd.mm.yyyy')
The [#] indicates where the cursor should be.
In the AutoReplace text you can now refer to the template:
td=SQL Functions\to_date.tpl
When typing "td" the template text will now be inserted and the cursor will be located at the position of the [#]. The [#] will of course not be inserted.
