7.1. Copy non-English text from any sql-output, Paste it! Result - wrong codepage
Puxmep
7.1 Version
Copy non-English text from any SQL-output, then Paste it (in other window for example)!
Result - wrong codepage...
First - select this select "select name from firm"
I see like this
NAME
АБАКАНСКАЯ ТОРГ.БАЗА ТУВИНСКОГО РЕСПОТРЕБСОЮЗА
АБАКАНСКИЙ ЗАВОД "ГАЗСТРОЙДЕТАЛЬ"
АБАКАНСКИЙ ЗАВОД КПД
АБАКАНСКИЙ СТАЛЕЛИТЕЙНЫЙ ЗАВОД
АБАКАНСКИЙ ФИЛИАЛ ОАО "ВОСТОК-СИБПРОМТРАНС"
АБАКАНСКОЕ МОНТАЖНОЕ УПРАВЛЕНИЕ ВОСТОКСАНТЕХМОНТАЖ
АО МАГ СПОРТТОВАРЫ
АО ХАКАССНАБСБЫТ
АОЗТ "ТРИКОТАЖНАЯ ФИРМА ХАКАСИЯ"
АОЗТ ХЛС-САЯНЫ
Then copy result in the SQL-Output
then paste... (in SQL-Window)
This is result
It works for me too.
Additional information
SQL> select * from v$nls_parameters where parameter like '%CHARACTERSET';
PARAMETER                    VALUE
NLS_CHARACTERSET             WE8ISO8859P1
NLS_NCHAR_CHARACTERSET       AL16UTF16
SQL> desc russian_chars
Name Type          Nullable Default Comments
ID   NUMBER        Y
TEXT NVARCHAR2(99) Y
select * from v$nls_parameters where parameter like '%CHARACTERSET':
My result:
PARAMETER VALUE
NLS_CHARACTERSET CL8MSWIN1251
Hm...
If I switch language to Eglish, then copy Russian text: result is wrong codepage...
But!
If I switch language (before copy) to Russian, then copy Russian text: result is normal codepage!!!
I have the same problem.
If I switch the language to German before copying, then the copied and pasted text has an incorrect encoding, but a query with this text retrieves matched rows.
If the current language is Russian, then the text has the right encoding, but the query finds no matches.
Example:
select bezeichnung from verbrauchsarten where bezeichnung = '
Is there a workaround for this problem?
We are not able to run queries on our customer's databases from Dev. 7.1.
Please help!!
