I work in win7-64 environment.
I installed 32 bit oracle client and worked for a long time with no problems.
I needed to install 64 bit client to enable 64bit programs to connect to oracle.
I installed it to a different home.
When I was installing I had an instance of PLSQLDEV open. That instance connected before I installed the 64 bit client.
After the 64 bit oracle client installation, connection from sql plus was OK for both clients.
The already opened instance of PLSQLDEV continued to work fine. I disconnected and connected with no problems.
A new instance of PLSQLDEV did not connect with error message ORA-12557.
I tried to configure the connection to use home1 with the correct OCI for the home1 folder. It didn't change the connection problem.
Info enclosed:
PL/SQL Developer
Version 10.0.5.1710
01.88464 - 1 user license
Physical memory : 4,194,304 kB (4,152,840 available)
Virtual memory : 2,097,024 kB (1,857,864 available)
Parameters
D:\Program Files\PLSQL Developer 10\plsqldev.exe
DebugSQL
Preferences
Session mode: Multi
OCI Library: D:\oracle\product\11.2.0\client_1\bin\oci.dll
Use OCI7: False
Preference Files
D:\Program Files\PLSQL Developer 10\Preferences\Default\Default.ini
C:\Users\israel\AppData\Roaming\PLSQL Developer\Preferences\israel\default.ini
Plug-Ins
*Active Query Builder (D:\Program Files\PLSQL Developer 10\PlugIns\ActiveQueryBuilder.dll)
*PasteOptions 1.2 (D:\Program Files\PLSQL Developer 10\PlugIns\PasteOptions.dll)
PL/SQL Documentation (plsqldoc) (D:\Program Files\PLSQL Developer 10\PlugIns\plsqldoc.dll)
Red Gate Deployment Plug-In (D:\Program Files\PLSQL Developer 10\PlugIns\RedGate.dll)
Version Control Interface 1.2 (D:\Program Files\PLSQL Developer 10\PlugIns\VCS.dll)
(* is Active)
Aliases
GADIRDEV
GADIRPRD
ZGADIRPRD
Homes
OraClient11g_home1 (D:\oracle\product\11.2.0\client_1)
DLLs
TNS File
D:\oracle\product\11.2.0\client_1\Network\Admin\tnsnames.ora
Using
Home: OraClient11g_home1
DLL: D:\oracle\product\11.2.0\client_1\bin\oci.dll
OCI: version 11.1
TIA,
gad
Info enclosed:
PL/SQL Developer
Version 10.0.5.1710
Parameters
DebugSQL
Preferences
Session mode: Multi
Use OCI7: False
Preference Files
Plug-Ins
(* is Active)
Aliases
GADIRDEV
GADIRPRD
ZGADIRPRD
Homes
DLLs
TNS File
Using
OCI: version 11.1
TIA,
gad
		 ATH=;;"). Read "Command-line parameters" section of PL/SQL Developer Manual (User's Guide) for details.
