whip
I had posted an issue in the beta forum which has not been addressed yet. The beta forum is R/O so I post it here again:
My settings for indentation:
Indent:
Automatic: on, step: 4
Tabs & Wrapping:
Smart Tab: off, tab size: 4
Smart fill: off
Use tab character: off
In a new SQL window I type "SELECT" then press Enter. At this point the cursor is in the first column.
When I press TAB, the cursor gets to column 2 instead of 5.
Next tab moves the cursor to column 6 (previous position plus 4 chars)
Next tab moves the cursor to column 9 (previous position plus 3 chars), the cursor advances by 4 chars afterwards.
The correct positions I think are: 1, 5, 9, 13 etc.
Indent:
Tabs & Wrapping:
Smart fill: off
