Christo Kutrovsky
PL/SQL developer's explain plan query ordering is not correct. Sometimes the order of the plan will not be correct.
For example, when having a HASH-JOIN subkey, the tables will be replaced. (the hashed table will be second...).
The query you are using is:
select level, plan_table.* from plan_table where statement_id = 'TEST'
connect by prior id = parent_id and statement_id = 'TEST'
start with id = 0 and statement_id = 'TEST'
The proper query to use would be:
order by id, position
I have some ideas on improving explain plan. If you are willing to do changes on the entire window please let me know.
I am also willing to throw in some developement help if you are interested.
