Version 13.0.4.1906 (32 bit)
I have package with 2 functions:
I have object with 2 attributes:
If I want to access lrItem in FuncBBB, autocomplete wrongly shows attributes from FuncAAA
If I try to rename to new lrItem1, then autocomplete shows correct attributes from objekct myStorage
CREATE OR REPLACE PACKAGE myPackage IS
FUNCTION FuncAAA(
aaa NUMBER
) RETURN NUMBER;
FUNCTION FuncBBB RETURN NUMBER;
END myPackage;
CREATE OR REPLACE PACKAGE BODY myPackage IS
FUNCTION FuncAAA(
aaa NUMBER
) RETURN NUMBER IS
FOR lrItem IN (SELECT 1 AS A, 2 AS B FROM dual)
LOOP
NULL;
END LOOP; -- resources
RETURN 0;
END;
AS
lrItem1 myStorage;
lrItem1 := myStorage(1, 'B');
END;
END myPackage;
CREATE OR REPLACE TYPE myStorage FORCE AS OBJECT
num NUMBER,
var VARCHAR2(250)
) NOT FINAL;
