Wish List: Add to PLD help - Login.sql and AfterConnect.sql
CTzen
Marco,
is it possible to add to help file list of sql files PL/SQL Developer calls and their proper usage? E.g. loging.sql and afterconnect.sql, what windows (command, sql, test) can and cannot use them, etc.
We'll add this to the documentation.
AfterConnect.sql is called for all sessions created within PL/SQL Developer. Login.sql is called by the Command Window.
Documenting this would be helpful. It took me a while to figure out where the file was located, and how it works. (For example, the file is run every time a new session is created, but doesn't seem to be re-read from disk until the program is restarted.)
Jon
So where is it? (It's still not documented, and whenever it's mentioned in forum posts they just say the filename.)
I found one by searching the PL/SQL Developer installation directory, however that is readonly by default in Windows 7 so I'm hoping there is a configurable or implicit search path that includes my home directory.
Edit: just found another thread which states that as of 2012 AfterConnect.sql has to be in the installation directory: Running script on login
As that is a read-only directory, I wouldn't say that was much use as a configuration option :(
