Will not connect using HostName. Connects using IP Address
jangjangjang
I currently installed the new version 9.06 and somehow when i connect, it will connect only if i put the ping'd IP address on the TNSNAMES HOST NAME but it wont recognize the HOST NAME
ex: My old Tnsnames has this and it wont connect
HOST = erpqa00.sc.esilicon.com
But if i change it to below then it connects. Any ideas?
HOST = 10.1.1.1
if the TnSNAMES looks like this it works
ERPTST.SC.CO.COM =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = 10.1.9.44)(PORT = XXXXX))
(CONNECT_DATA =
(SERVICE_NAME = ERPTST)
but if this way, it wont work
ERPTST.SC.CO.COM =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = ERPTSTDB.SC.CO.COM)(PORT = XXXXX))
(CONNECT_DATA =
and normally i dont care as long as it works but i found there are data inconsistencies that i noticed when doing this. I have a server where i still have the old version and uses the hostname instead of the IP address. Here i get all the data i need. In my new machine, sometimes i go to Oracle Applications and update a record but i dont immediately see this in my new machines point to the IP Address.
jangjangjang said:
Yes. When i tnsping the hostname of "erpqa00.sc.esilicon.com" it gives me the ip address.
Are you using ping or Oracle's TNSping?
You will need to use tnsping to check if it can be resolved. For example:
TNSPING ERPTST.SC.CO.COM
(database name copied from your most recent post)
