Where Clause Generated with QBE
BlueNitro
When I use the TOracleNavigator to run a QBE. How do I get the where clause that it generated to retrieve the data?
Thanks!
After executing the QBE query, the SQL property of the dataset contains the modified SQL, including the where clause.
Thanks, but I've already found that out.
I was just wondering if there was a way to get just the new sql that was added.
Also, it creates variables like :doa__qbe7, :doa__qbe8. Does it always start at 7 and increment from there? Why does it start at 7?
There is no functionality to obtain the SQL that was added. Your application would have to compare the original SQL and the QBE SQL.
The variable name :doa_qbe7 indicates that this is a QBE variable for the 7th dataset field.
