What settings to tweak PL15
zitot
I don't have PLSQL Dev 16 yet. I'm not sure when our IT dept will approve it, but it's been a few months so.
1. Is there graphics acceleration available for 15? If so, where do I find this setting?
2. I disabled CLipboard History.
3. I set Light theme to , But I am using some dark mode themes... I heard that 16 supports dark mode better, is that true?
4. Does multi document mode work better in 16 than 15? For me it was glitching and hard to manage the windows, so I went back to just having two connections to the DB in separate instances of PLSQL Developer.
5. Does 16 support stretching across multiple monitors?
6. Are there executable commands that I can add to the launcher?
Version 16 does indeed improve many UI rendering functions. Perhaps you can try the trial version in a test environment to verify. It does not stretch across multiple monitors though.
