Viewing LONG/Ref Cursor values
Hello Everyone
I was wondering if there is a way to view the values of a Long Variable or any variable defied as VARCHAR2(1000) or greater during debugging.
Also is there a way to view the value(s) of a REF CURSOR type.
i.e. OPEN AllRecs FOR select * from dual;
Can we view the contents of AllRecs if AllRecs is defiend as a REF CURSOR datatype ?
Many Thanks.
Bev
The Oracle Debug API is limited to about 1000 characters. Longer values cannot be displayed.
What do you mean by "the value(s)"?
Thank you for the prompt reply.
Regarding my second question:
When a Ref Cursor type is "opened" and "filled" with values/rows can the values of those rows be seen in the debugger?
i.e OPEN AllRecs FOR Select Owner, Empno FROM EMP WHERE EmpNo = 15;
This SQL should "get" Owner and Empno "into" AllRecs (ref cursor datatype). So can I see the contents of AllRecs. I know that the Debuggers shows the RecordCount etc.. but is it possible to actually see the data as it is possible to see the data in a "collection" object ?
Thanks again
The only way to view the cursor data it to fetch it into one or more variables. You cannot view an entire row or result set.
