Hi.
When I use (View Table) window or (Edit Table) window and press "View SQL" button , the program does not display disabled constraints correctly. for example:
alter table ACCOUNTS
add constraint ACC_NAME_UK unique (NAME)
novalidate
disable;
where it should be:
disable
novalidate;
So the (disable) word must be before (novalidate).
novalidate
disable;
where it should be:
disable
novalidate;
