Sergei.Agalakov
Let's start from some minor problems.
First, help isn't updated in 7.0.3; there isn't anything about unicode support here. I was trying to look for "Unicode enabled" item in Preferences->Oracle->Options and a screenshot just doesn't have this checkbox. A search in help for "unicode" didn't produce any results either.
Second, I do have Oracle 10gR2 client installed but when I click on 'About' in help menu I see a meassage that I use OCI version 9.2 (path for oci.dll is correct, and shows 10.2 directory).
I have created a table UTEST with nvarchar2(1000) column, have populated this column in SQLDeveloper with the texts on the different languages from www.bbc.com and was trying to see this data in PLSQL Developer.
In SQL window all non-English text is presented in vertical bars. When I click on [...] then I do see some international code but:
- Russian looks fine in both text and RTF
- Persian looks differently in text window and RTF window. Text window isn't properly refreshed for Persian language, some pieces of buttons are visible here.
- Arabic looks differently in text window and RTF window.
- Hindi isn't visible in text window (shows squares) at all, visible in RTF.
- Hex windows uses the same font as text window and shares the same problems.
- RTF window shows tool bar to choose font and font properties but you can't change nor font nor its properties.
- HTML and XML windows don't show non-English text, XML shows vertical bars in preview, HTML uses two-byte notation.
I have tested only Russian, Arabic, Persian and Hindi. There are more available on http://www.bbc.com and sure you can find more elsewhere.
