Vers. 10 changed behaviour for selecting templates
Benjamin L
In Vers 9 i could select templates without using the mouse.
When i pressed the shortcut for "Tools/Template List"(F2) the shortcuts, had automatically the focus, so i could navigate through with cursors and select one template with return.
In vers. 10 i have to click with the mouse in the Template List.
This solution is very slow. Plz. fix it or tell me the option to change this.
After pressing your shortcut key to display the template list, press TAB and the focus should go to the template list allowing you to use only the keyboard without using the mouse.
hope it help you
@Marco: The templates are in a docked window, but the behaviour is the same if they are in a floating window.
@Martin: Thanks for the workaround, not perfect, but definitly useful
