ver 7.1.3.1381 Numeric display errors for large decimals
limsk
Am encountering some display errors with numeric columns with large decimal precision.
This example script should simulate the error:
create table example
CRR_VALU NUMBER(30,15)
insert into example (CRR_VALU) values (545.1);
insert into example (CRR_VALU) values (249.2);
insert into example (CRR_VALU) values (18886.56);
commit;
SQL> select * from example
2 /
CRR_VALU
545.100000000000023
249.200000000000017
18886.560000000001300
We are using PL/SQL developer version 7.1.3.1381
Is this something that is fixed in version 8?
This is indeed a known floating point precision restriction. For the SQL Window you can enable the "Number fields to_char" preference (Tools > Preferences > SQL Window). This way the number values are converted to a character representation on the server with full Oracle precision.
