VCS - Reserved checkout mode fails on commit
tfferreira
I'm having a problem related with VCS and Reserved checkout mode.
After activate the Reserved chechout mode in the SVN options tab menu I can lock a package.
If I checkout the same package in another machine plsqldev show a warning message "saying" that file is lock. This is ok.
The problem resides when I try to commit the changes. A popup is displayed with the following message :
COM.SvnClient.Error, HRESULT=0x80020009
Commit failed
Pressing the OK button another message is displayed :
Non specific error.
OS : XP Pro 5.1 Build 2600 (SP2)
Regards
Tiago
I'm using the PushOk SVNSCC plugin to contact subversion (1.4.2).
I've tested this in different XP machines and the result is the same.
I've tested also in Windows Vista and it works on that system.
Tiago
