VCS - CVS Clients for PL/Sql Developer
rene.heusser
Currently we are using Jalindi Igloo for the VCS plugin.
But we are facing more and more problems with it, since the standard connection to our cvs has changed to ssh.
Could anybody recommend what shall be used instead of Jalindi.
I have an XP box, cvs is on Linux.
Thank you for any hint and advice.
Rene
Rene,
We started using ComponentSoftware's CS-RCS vcs software about 4 months ago and are very pleased so far. Low cost, low overhead, good functionality, decent tech support. It supports connecting to an RCS repository, though we use their repository software instead.
They also make a product for connecting to CVS, though I have no experience with it.
Worth checking out:
http://www.componentsoftware.com/products/cvs/solution.htm
Best of luck.
Thank you for the tip.
I have downloaded CS-RCS and at first glance it looks fine, but then I encountered that I would also need CVSNT to run it against the repository, which is exactly where I have my problems.
I can connect to the cvs, but I cannot checkin again. Sometimes I even get an abort during the checkout.
So I have to look further into the connectivity issues with CVSNT, instead of doing development.
Thanks again for your help.
Rene
