VCS branch management
PhilG
Is there any documentation how to use branch on VCS connected to CVS with 'PushOk CVSSCC NT' gateway.
I succeed creating a branch but cannot "put" any package version in this branch, no way to chose the branch when check-in the package.
Any advice?
thanks
I'm not familiar with PushOK, so I can only provide some general comments.
Branching is not a known concept within the SCC interface specification, so any control over branching will have to be done from the PushOK check-out or check-in forms.
It can also be available in an "Option" function. Perhaps if you go to VCS > Preferences and enable the "Show Options for" / "Check In" option, some more PushOK functionality is exposed.
Thanks for your answer, I didn't realize before what was from VCS and what was from PushOK, so didn't read the right doc for the right action.
PushOK is working perfectly for Branch management.
I've choosen it instaed of Igloo because it's newer (2006 version vs 2001 for Igloo )and better integrated to CVS, especially V2.0.58 and above. On top of that ssh is seamlessly integrated.
Only small issue it's 19$ per seat.
