VCS and Borlands StarTeam
wes
I am having a problem using the VCS with StarTeam
I can establish the project OK, but the directory selection for "check out" does not display any sub-direcotries.
When I initially opened the project, I setup the Local Path as g:\project\top-dir The "g" drive is a netwoked drive on a server that contains all our source code.
When I attempt to perform a check-out, I see only the top directory, no sub-direcotries where the various code is stored
Any ideas?
It seems that the StarTeam SCC interface does not report controlled directories. I will try to verify this.
I have the same problem. I installed the MS SSC Integration software coupled with Star Team. The integration works fine with other development packages. I used the integration to interface with Rational Rose Java Edition.
Has anyone found a resolution to this issue with the interface to PL/SQL developer?
The original poster resorted to opening starteam in a seperate window, as have I.
Glen
Any ideas?
