Claus Pedersen
When using Alt+ and Alt+ to do 'browser style' navigation between windows, strange characters are written to the files being edited.
When you do not notice the characters written by PLD and just saves the file, false data is written to the file when saved. This may lead to most unwanted results.
Steps to reproduce:
Open two new windows. e.g. a test window and an SQL window. The SQL window is currently active. The Navigate Back icon with the green left arrow is enabled (i.e., I can navigate back to the test window).
I press Alt+ to navigate back to the test window. When I release the Alt key after navigation, a '?' is printed in the test window. WHAT?
The Navigate forward icon (green right arrow) is enabled, but the drop down list is empty.
If I press Alt and two times , PLD writes 'B'. If I press Alt and three times , a 'U' with an "umlaut" (German style Y) is written. Depending of the number of times I press and or , all types of characters are written.
How do I disable 'browser style' navigation in PLD? Of course, I do not want PLD to mess up my program/command files.
I could of course just avoid using Alt-Right and Alt-Left, but I sometimes hit them instead of Ctrl-Right and Ctrl-Left which I use a lot to navigate in code.
Steps to reproduce:
